How can I delete an entry in dconf-editor?
I want delete completly pluma because I use another editor.
I don’t think you can. The schema are installed with the application package. You could try gsettings reset-recursively org.mate.pluma to reset all the settings. I haven’t tried it, but it looks like it would work.
I did it “gsettings reset-recursively org.mate.pluma”
No such schema “org.mate.pluma”
But in “dconf-editor” it’s still there.
The reset command just brings them back to default values, it doesn’t remove them. You would need to remove pluma, modify the schema files, and recompile gsettings schemas for that.
The question is why? gsettings is an internal database, not user-controlled generally
Why? Quite simply, as Gnome and their stupid MSWin-like "registry" doesn't provide a SANE way of managing settings. If you need to restore some, but not all settings from an older install, you have to perform complex hackery to export then re-import settings. Something that could be done with little effort or trouble in NORMAL text files.
But this is the Gnome way; if it's something you need to do, you aren't allowed to do it.
thanks for the info @ jelabarre59
Hi again.
Hi!
I uninstalled all packages from "brasero".
In dconf-editor the path to "/org/gnome/brasero/" was not removed.
When I run dconf reset -f "/org/gnome/brasero/" it only reset the dconf path to "/org/gnome/brasero/" and it's keys to default values.
A command like dconf remove /path-to/ /path-to/key would be good.
I also did a test:
dconf dump / > dconf_user_backup
rm /home/user/.config/dconf/user
Logged out.
Logged in.
Edited the backup dconf dump file with a text editor: "dconf_user_backup"
Removed all Brasero entries include it's path from:
/org/gnome/brasero/
'saved file'
dconf load / < ./dconf_user_backup
dconf update /
Rebooted PC.
The entries in "/org/gnome/brasero/" are still there. ![]()
Did a test.
Installed Brasero packages.
After that, rebooted.
Then:
sudo apt purge --remove brasero
Rebooted.
dconf-editor still shows the path to brasero even though it is not installed.
Path and keys cannot be deleted.
Is it possible to hack the
org.gnome.brasero.gschema.xml
so that the path to org.gnome.brasero disappears?
here is the gschema of Brasero:
<schemalist> <schema id="org.gnome.brasero" path="/org/gnome/brasero/"> <key name="nautilus-extension-debug" type="b"> <default>false</default> <summary>Should Nautilus extension output debug statements</summary> <description>Should Nautilus extension output debug statements. The value should be set to true if it should.</description> </key> <child name="config" schema="org.gnome.brasero.config"/> <child name="display" schema="org.gnome.brasero.display"/> <child name="filter" schema="org.gnome.brasero.filter"/> </schema> <schema id="org.gnome.brasero.config" path="/org/gnome/brasero/config/"> <key name="checksum-image" type="i"> <default>0</default> <summary>The type of checksum used for images</summary> <description>Set to 0 for MD5, 1 for SHA1 and 2 for SHA256</description> </key> <key name="checksum-files" type="i"> <default>0</default> <summary>The type of checksum used for files</summary> <description>Set to 0 for MD5, 1 for SHA1 and 2 for SHA256</description> </key> <key name="tmpdir" type="s"> <default>''</default> <summary>Directory to use for temporary files</summary> <description>Contains the path to the directory where brasero should store temporary files. If that value is empty, the default directory set for glib will be used.</description> </key> <key name="engine-group" type="s"> <default>''</default> <summary>Favourite burn engine</summary> <description>Contains the name of the favourite burn engine suite installed. It will be used if possible.</description> </key> <key name="plugins" type="as"> <default>[]</default> <summary>White list of additional plugins to use</summary> <description>Contains the list of additional plugins Brasero will use to burn discs. If set to NULL, Brasero will load them all.</description> </key> <key name="immed-flag" type="b"> <default>false</default> <summary>Enable the "-immed" flag with cdrecord</summary> <description>Whether to use the "-immed" flag with cdrecord. Use with caution (set to true) as it's only a workaround for some drives/setups.</description> </key> <key name="dao-flag" type="b"> <default>false</default> <summary>Whether to use the "-use-the-force-luke=dao" flag with growisofs</summary> <description>Whether to use the "-use-the-force-luke=dao" flag with growisofs. Set to false, brasero won't use it; it may be a workaround for some drives/setups.</description> </key> <key name="minbuf-value" type="i"> <default>0</default> <summary>Used in conjunction with the "-immed" flag with cdrecord</summary> <description>Used in conjunction with the "-immed" flag with cdrecord.</description> </key> <key name="raw-flag" type="b"> <default>false</default> <summary>Whether to use the "--driver generic-mmc-raw" flag with cdrdao</summary> <description>Whether to use the "--driver generic-mmc-raw" flag with cdrdao. Set to True, brasero will use it; it may be a workaround for some drives/setups.</description> </key> </schema> <schema id="org.gnome.brasero.display" path="/org/gnome/brasero/display/"> <key name="iso-folder" type="s"> <default>''</default> <summary>The last browsed folder while looking for images to burn</summary> <description>Contains the absolute path of the directory that was last browsed for images to burn</description> </key> <key name="viewer" type="b"> <default>true</default> <summary>Enable file preview</summary> <description>Whether to display file preview. Set to true to use it.</description> </key> </schema> <schema id="org.gnome.brasero.filter" path="/org/gnome/brasero/filter/"> <key name="hidden" type="b"> <default>true</default> <summary>Should brasero filter hidden files</summary> <description>Should brasero filter hidden files. Set to true, brasero will filter hidden files.</description> </key> <key name="replace-sym" type="b"> <default>true</default> <summary>Replace symbolic links by their targets</summary> <description>Should brasero replace symbolic links by their target files in the project. Set to true, brasero will replace symbolic links.</description> </key> <key name="broken-sym" type="b"> <default>true</default> <summary>Should brasero filter broken symbolic links</summary> <description>Should brasero filter broken symbolic links. Set to true, brasero will filter broken symbolic links.</description> </key> </schema> <schema id="org.gnome.brasero.plugins"> <key name="priority" type="i"> <default>0</default> <summary>The priority value for the plugin</summary> <description>When several plugins are available for the same task, this value is used to determine which plugin should be given priority. 0 means the plugin's native priority is used. A positive value overrides the plugin's native priority. A negative value disables the plugin.</description> </key> </schema> <schema id="org.gnome.brasero.drives"> <key name="flags" type="i"> <default>1</default> <summary>Burning flags to be used</summary> <description>This value represents the burning flags that were used in such a context the last time.</description> </key> <key name="speed" type="i"> <default>0</default> <summary>The speed to be used</summary> <description>This value represents the speed that was used in such a context the last time.</description> </key> </schema> </schemalist>
hmm, edited file "org.gnome.brasero.gschema" in
"/usr/share/glib-2.0/schemas
to:
<schemalist> <schema id="" path=""> </schema> </schemalist>
dconf update
Rebooted.
Nothing is changed in "/org/gnome/brasero/" (dconf-editor)
the answer will resolve your problem:https://askubuntu.com/questions/45535/how-do-i-clean-up-my-dconf-database/85755#85755?newreg=8d469e6a89144c1d83d52d3d773945d1
Thanks, but I have already read that and have tried it out.
Did not work for me.
