How can I disable Mate HUD permanently?
When i reboot my PC, Mate-HUD in Autostart is starting.
I deleted the Entry at Autostart. But it comes back.
In dconf I set them to false.
Hi @mate2go, Try MATE Tweak under Panels. I played with manually editing the .desktop file to kill it in Startup but the MATE Tweak setting works fine.
In the past, I disabled it in MATE Tweak. But it comes back when I remove it also in Autostart (mate-session-properties)
Also disabled it in dconf-editor.
I haven’t seen the MATE Tweak enable come back. Yes, the Startup insists on staying and being checked.
Maybe the combo ends up enabling the MATE Tweak setting. Make sure to not change Startup - let it be there and checked. Does the MATE Tweak setting now behave?
I've done:
sudo chmod -x /usr/lib/mate-hud/mate-hud
In Mate-Tweak, MATE-Hud is unchecked,
after REBOOT MATE-Hud is checked again
How can I prevent MATE-Hud to be checked again in Autostart (mate-session-properties)???
I hope I got it now:
sudo apt purge --remove mate-hud
