Pluma is the default text editor.
To add a spell checking language, install the respective aspell package.
For example, to add German, install aspell-de.
Now you can select a different language from the menu by going to Tools > Set Language.
Does using Ubuntu MATE Welcome to install Language Support achieve the same result?
