hi, i use mega storage i got the little utility to sync all the files on my local PC. i don’t use the default directory i use an folder an other dirve and because it will not mout itself on boot any time i log in the mega sync app give me an error “the selected folder can’t be found”. how i automout harddisk on boot to fix this issue?
Create an fstab entry for it?
how i can create an fstab entry?
OK after reading your links i was finally able to automount a drive on the boot!
thanks!
