I want to block kernel upgrades because i use the last kernel 4.9.
I use Synaptic, but i'm not sure if it's correct:
Hi avestruz123
Using synaptic you can lock the kernel.
http://www.ubuntugeek.com/how-to-lock-package-versions-from-synaptic-package-manager.html
That should stop an upgrade.
or
To remove all kernel upgrades, remove the three meta-packages.
