I’m trying to make a multi-track recording from my old keyboard and I want to connect the line input to the headphone jack and simultaneously record it. Is this possible?
Yes it is possible using PulseAudio. You will need to install pavucontrol -
sudo apt -y install pavucontrol
and then follow the directions here:
https://www.linux.com/learn/weekend-project-record-skype-calls-and-other-apps-linux
(Although this example is for skype, the same basic tools for creating pulseaudio virtual devices and connecting them together apply to most any application.)
