I love that Tilda comes pre-installed on UM. Use it all the time. But the default colors are set up to fit into Radiant-Mate the best, and I’m playing around with my themes right now. I’ve changed to Blue-Submarine and I’d like to customize my system to fit in with blue (for now at least). Gray Tilda just doesn’t fit.
How do I customize Tilda, and where is the default Tilda config stored? Is it a dotfile somewhere? I don’t want to overwrite it if I wish to return to it later. Should I create a .tilda
file (or something) in my home folder? Will running the tilda -C
command and changing the settings in the menu that pops up create one? Couldn’t find any docs on this.
Thanks!
