I have a USB which was formated on my Win10, there is music on it from my Win10, I’ve inserted it into the Umate USD port but can’t find it, I assumed a message would pop up>
It should show up in Caja (the file manager)'s sidebar under Devices. If you don’t see it there, I’d open Disks and see if shows up there.
AWESOME! found caja and found usb! Many Thanks!
