Similar to the gray background highlighting of @names, I keep seeing posts with phrases highlighted. This is great for combining compound nouns or variable/data pairs.
OK, I give up, how’s that done???
Hi @wolfman Maybe my preview is screwed up because if I try to highlight > this text it doesn’t show correctly. Just sticks a greater-than in front.
I’m referring to text in a sentence highlighted. Here’s an example from @marfig: Desktop keyboard shortcuts don’t work with conky
Blockquote looks good for multiple code lines, though:
Code line 1
Code line 2
See how this posts.
edit: yeah, tried to highlight “this text” in first sentence using blockquote - didn’t work.
Use back ticks
` this is highlighted if I finish it with another backtick.
I think the proper name is inline quote, or inline code
Hehe… I think that does it!
I tried single and double quotes but not backtick/accent. Thanks!!!
OK, extended information is called for and this post is partly to confirm all my findings.
Basically, a pair of backticks
, <code></code>
and </> Preformatted text
. ALL DO THE SAME THING!
Yes, the backtick works fine as done here to demonstrate
So does <code>THIS</code>
which I put between backticks so the "code"s display in the post. That’s an important point. I find I cannot reverse that order to display backticks and the attempt puts the post minimized!
But there’s even more. It turns out @wolfman was only one menu symbol off the answer, too. I thought the </> function called “Preformatted text” formatted code lines. Then I discover it forces backticks around selected text!!! So there’s another way
to accomplish the same thing!
Last, I looked up “backtick” and Wikipedia actually redirects instantly to Grave accent. I knew it was some kind of accent but not sure of details. Obviously, backtick is in heavy usage.
Thanks again.
Hi Bill,
I thought you just wanted a block quote, so yes as @marfig pointed out, use the other symbol but basically they are the same thing!.
Want more types of highlighting?
<ins>Text</ins>
produces this “insert” highlighting
<del>Text</del>
produces <strike>Text</strike>
produces a One more… if you like to be sophisticated.
<kbd>CTRL</kbd>
produces CTRL
Also, for proper code highlighting, you can add 4 spaces at the start, and optionally specify the language (if it wasn’t detected properly):
```bash
echo "Test"
echo "Test"
```python
import time
def this(self):
print("Test")
import time
def this(self):
print("Test")
