Curious if its possible to add a sound when the notification bar appears, since I sometimes miss it because I am using a phone and not looking at the monitor.
I donât think itâs possible as such.
If you open a terminal and type in ânotify-send --help
â youâll notice there is no option to have a sound playing.
However, some applications that trigger notifications can also have an option to play sounds.
For instance, HexChat (the IRC client) has an option to send notifications in Chatting -> Alerts under the misleading denomination âShow Tray Balloonsâ, but it can also make beep sounds.
@mated Checked there, and I have the same settings as you, but I donât get sound when receiving an email notification. Seems its like @ouroumov said, it probably is application dependent. Using Geary btw, and didnât find an option for sound.
Thanks for the info guys.
Sorry for the bombardment of screenshots; this covers most of the rest of any toggled off sound defaults.
That last one may do it for you, as this app sound enabler is defaulted off; but I don't use Geary.
Don't give up, if you need the feature; there is a way, somewhere!
Don't worry I don't mind a lot of images. Well, looked through those settings and set the sound same as you, but no luck. I did, however, find one of Geary, and it had a play sound notification. Then found it on Geary's preferences button, I could have sworn that option wasn't there. Anyway, checked marked all the display sounds, sent an email to myself to test, but still a soundless notification. Maybe its still in development?
Some images:
I gleaned through these two, and didnât find a specific solution for this challenge; but I thought I would let you check them them out for GP, if you havenât already.
Also, Thunderbird (settings maybe) could perhaps play a role, as would something we missed, or a sound theme debacle, or an absent file or misconfiguration.
Which version of Geary? 0.11 has been recently released, perhaps this is a bug theyâve fixed.
The other reason I can think why is if itâs trying to play from a specific sound file (rather then system default)?
@mated Saw the help page, and the wiki, nothing there about it just a mention that it has an option for sound notification.
@lah7 Using the 0.11 version gotten from here. Pherhaps the bug is one of those that you spray and it lies there for a min, then escapes.
So just an update, I know get a sound when I get a new email. It seems it might have been a problem with Pulseaudio that was fixed in its recent update?
Btw, any way to stop notifications from changing its theme every time I change my windows/icon/border theme? I have it set up to coco, but when I change my overall theme it goes back to the stadard notification theme.
in Gnome3, it uses message.oga
#I used this for jurassic park satellite phone ringtone
ffmpeg -i jurassic.mp3 -c:a libvorbis output.oga
sudo cp output.oga /usr/share/sounds/freedesktop/stereo/message.oga
Has anyone had sucess with ever getting this working? I canât believe this isnât a more requested feature. Leave your computer for 10 seconds and you never knew you missed anythingâŚcould you have a continuously-running script that monitors the wm whenever ânotify-sendâ is invoked, and when it does, uses something like sox to play a sound?
