Does anyone know of any GUI software that will allow you to create a bootable USB in arm64 such as etcher?
Ok I'll have to try the gnome disk imager. I couldn't find an image for etcher that will work on Ubuntu arm64.
rpi-imager https://github.com/raspberrypi/rpi-imager
Were you able to build that on Ubuntu? I got errors...
https://archive.raspberrypi.org/debian/pool/main/r/rpi-imager/rpi-imager_1.4_arm64.deb
sudo dpkg -i /Downloads/rpi-imager_1.4_arm64.deb
Change "Downloads" to correct path to locations package downloaded.
Awesome, thanks a bunch!
