I'm running MATE Desktop 1.24.1 on openSUSE Tumbleweed.
There is a keyboard shortcut Alt+7 which acts similarly to Alt+Tab, but it switches between open windows in the same group. For example if I have multiple Firefox windows open, I can switch between them sing Alt+7 (see screenshot). I would like to disable this shortcut as it conflicts with another shortcut in one of the graphical programs I regularly use.
I checked all options in MATE's keyboard shortcuts preferences, but I didn't find any action with Alt+7 listed there. I also checked keyboard shortcut settings using dconf editor under /org/mate/marco/.
In the windows switcher panel applet's Window List Preferences window, I have "Never group windows".
So far all my attempts have failed to disable Alt+7. Do you have any idea how to do that?
There's only one <Alt>7 which is clearly not relevant here.
Yes, it does, but it conflicts with this one and Firefox only reacts to Alt+num7 where num7 is 7 on the numpad. Also, same behaviour happens for other apps as well, for example here I have 2 sublime text windows open:
After digging ~1 hour in Marco's source, I found that the setting responsible for this was org.mate.Marco.global-keybindings.switch-group with default value <Alt>grave. It turns out that on my keyboard layout grave (`) is on the key 7 and can be entered with AltGr+7. For some reason Marco was picking up Alt+7 as Alt+grave. This is possibly some minor bug.
It's a frequent problem in almost all languages except English, I guess.
[ alt ] + [ tab ] and [ alt ] + [ key above tab ] shortcuts are often associated with « application switcher » and « window from an app' switcher ».
The problem here is the symbol on [ key above tab ] depends on language and keyboard mapping.
⋅ on most english / qwerty keyboards [ key above tab ] is [ ` ] ( grave )
⋅ on a french / azerty, it's [ ² ] and this will vary with language and mapping.
Any app' using [ alt ] + [ key above tab ] shortcut should not rely on the symbol on the key but only on position of that key after keyboard mapping, sort of.
Therefore if the shortcut calls for [ Alt ] + [ grave ] instead of [ Alt ] + [ key above tab ] in many languages you end up with some awkward gesture, depending on [ grave ] position on your keyboard mapping ( which is [ 7è ] key above [ y ] on a french azerty, quite far from [ tab ] ).
It's not only Mate related, it's unfortunately true in all DE.
