Hey there,
I am using a micro SD card on my Rasperi-Pi 4 and I have ubuntu mate installed on it.
Seems like it has been set to read-only file system as I cannot format this SD card even with Gparted on a different linux machine.
The behavior of this is very similar to this article:
I can boot up the ubuntu and create new files and when I reboot it, it's gone.
I tried to use commands like sudo mount -o remount,rw /boot but it seems like it's not doing anything.
I also don't remember enabling it in the first place.
Does anyone know how to reverse it?
Thanks,
