How to enable FreeSync on Ubuntu Mate
- First we need to check the system kernel
Press :CTRL-ALT-T to open the terminal
Type in the terminal:
uname -r
This command will help you to see what kernel version you have. FreeSync is available from kernel 5.0 and up
- Check the monitor if it is vsync capable
Press :CTR-ALT-T to open the terminal
xrandr --prop | less
Check for the line vrr_capable:x, If it's 1 then the monitor is vsync capable , if is 0 then is not.
- Enable vsync on your system
sudo mkdir /etc/X11/xorg.conf.d/
echo -e 'Section "Device"
Identifier "Radeon"
Driver "radeon"
Option "TearFree" "on"
Option "VariableRefresh" "true"
EndSection' | sudo tee /etc/X11/xorg.conf.d/20-amd.conf
Reboot your OS
Check to see if vsync is enable on your OS
grep VariableRefresh /var/log/Xorg.0.log
Limitations
You can only use Freesync with DisplayPort as of kernels 5.x. Support for HDMI may be added in the future.
Freesync will only work for games and programs running full screen .
****For a more extensive tutorial you can take a look at https://linuxreviews.org/HOWTO_enable_Adaptive_Vertical_Sync_(Freesync)_on_AMD_GPUs
