How to get help?
Trying to respond to my earlier post for help with the requested input and get this message
Sorry, new users can only put 2 links in a post.
Seems like a perfect catch22 making support impossible!
Hello almost looks like you are still at TL0. Possibly this may help to clear up the question. Did not look up your other post so might be wrong.
https://blog.discourse.org/2018/06/understanding-discourse-trust-levels/
Did find your post and if you are in fact on TL0 you cannot post attachment.
Thanks for your help. Very complicated and makes getting support both complicated and time intensive. I've been using mate for years now but since I can't upgrade and can't get help I will probably move to ubuntu sometime before support for 2020 release ends.
With best wishes,
John
