Is there any way to get widevine running on 21.10? I've tried using the method here: https://github.com/monkaBlyat/docker-chromium-armhf
Which worked on 20.04, however it doesn't seem to work on 21.10, as it just ends with this:
I'm no Docker guru, or a Raspberry Pi guru, by any stretch. But let me chip in: Try rebooting. If you did an apt-get upgrade right before trying to use the Docker container of Chromium, and the upgrade installed a new kernel, the proper kernel modules will not be loaded since the operating system will be stuck in a somewhat inconsistent state.
To get Widevine support for Chromium browser running on Raspberry Pi OS, update the software sources, update your system, then install libwidevinecdm0:
