Hello,
I am packaging an application for visually impaired and I would like to have a keybinding packaged with that as well, so that the app can be easily launched. Any idea how to do that?
I thought I would package a gsettings override, something like
[org/mate/desktop/keybindings/custom0]
action='lios'
binding='<Alt><Mod4>l'
name='Linux Intelligent OCR Software'
But what if there is already "custom0" keybinding defined?
Thank you.
IMHO, to solve the task correctly, an installation package must include a script to verify possible keybindings conflicts, to preserve already existing customizations, etc.
Then you need to create "custom1" or edit "custom0", rather than replace it.
It looks like the following link might be of interest
Hi, @hamster and welcome to the Ubuntu MATE Community!
Approach: Dynamic Keybinding Management
- Check Existing Keybindings: Before adding your keybinding, query the system's existing keybindings to ensure you don’t overwrite user-defined ones.
- Find an Available Slot: If
custom0is occupied, you can iterate throughcustom1,custom2, etc., until you find a free slot. - Set the Keybinding: Use the
gsettingscommand or a script to create the keybinding. sample Bash script to dynamically assign your keybinding:#!/bin/bash
APP_NAME="Linux Intelligent OCR Software"
APP_ACTION="lios"
APP_BINDING="l"
Check existing keybindings
SCHEMA="org.mate.desktop.keybindings"
BASE_PATH="/org/mate/desktop/keybindings/"
CUSTOM_KEYBINDING=""
for i in {0..99}; do
KEYBIND="custom$i"
ACTION=$(gsettings get $SCHEMA.$KEYBIND action 2>/dev/null)
# If the slot is empty, use it
if [[ "$ACTION" == "@as []" ]] || [[ "$ACTION" == "''" ]]; then
CUSTOM_KEYBINDING=$KEYBIND
break
fi
done
Exit if no available slot found
if [[ -z $CUSTOM_KEYBINDING ]]; then
echo "No available keybinding slots found."
exit 1
fi
Set the keybinding
gsettings set $SCHEMA.$CUSTOM_KEYBINDING name "'$APP_NAME'"
gsettings set $SCHEMA.$CUSTOM_KEYBINDING action "'$APP_ACTION'"
gsettings set $SCHEMA.$CUSTOM_KEYBINDING binding "'$APP_BINDING'"
echo "Keybinding set to $CUSTOM_KEYBINDING with binding $APP_BINDING" Explanation
- Check for Available Slots:
- The script iterates over potential keybinding slots (
custom0,custom1, ...). - It uses
gsettings getto see if a slot is already assigned an action. - If it finds an empty slot, it stops iterating and uses that slot.
- The name, action, and keybinding are assigned using
gsettings set.
- Fallback:
If no free slot is found (unlikely for small apps), the script exits with a message. let me furher Bz-NeV2.... Considerations
Desktop Environment Compatibility:
- This example uses MATE (
org.mate.desktop.keybindings). If your app targets GNOME or another desktop, adapt the schema accordingly (e.g.,org.gnome.settings-daemon.plugins.media-keysfor GNOME).
Permission:
- Ensure the script runs with proper permissions. Some systems may require
sudoto modify global settings.
Customization:
- Allow users to configure the keybinding in case the default conflicts with their existing setup.
Packaging
Include this script in your application package and run it as part of the installation process or first-time setup. Alternatively, document it as a setup step for users who want the keybinding.
Hi, @neels_blizzard and welcome to the Ubuntu MATE Community!
Thanks....What a great Welcome..
Hello! I have spent numerous hours to work on this glib-compile-schemas issue that may interest you: glib-compile-schemas doesn't compile relocatable schemas
