I deployed new 20.04.x LTS systems and now I would like to cut all of that TTY7 stuff and move to runlevel 3 instead (multiuser+network).
Before, I used to do this:
But now, this doesn't seem to be working anymore:
$ sudo systemctl isolate multi-user.target
$ sudo systemctl enable multi-user.target
The unit files have no installation config (WantedBy=, RequiredBy=, Also=,
Alias= settings in the [Install] section, and DefaultInstance= for template
units). This means they are not meant to be enabled using systemctl.
Possible reasons for having this kind of units are:
• A unit may be statically enabled by being symlinked from another unit's
.wants/ or .requires/ directory.
• A unit's purpose may be to act as a helper for some other unit which has
a requirement dependency on it.
• A unit may be started when needed via activation (socket, path, timer,
D-Bus, udev, scripted systemctl call, ...).
• In case of template units, the unit is meant to be enabled with some
instance name specified.
So what would be the "official method" if one wishes to totally scrap GUI when using 20.04. LTS?
