Hello all,
I am running Ubuntu Mate 20.04, 64bit OS on Raspberry Pi 4 (4GB) varient and have initially installed Chromium Browser and tried playing Amazon prime video in it but it gave me an error saying incompatible browser or something then I searched online and found that the Chromium Browser doesn't have the built-in Widevine installed so I followed the website
And installed the media edition of chromium browser but now it shows an error
" Your browser is missing a digital rights components. Go to chrome://components and under WidevineCdm. Click check for update."
So I tried to go to settings and as soon as I open settings in chrome browser the settings page crashes with ( Aw snap). And I am not able to go to settings to check the Protected content is Allowed or not .
I also did try reinstalling chromium browser.
Can anyone please find a solution for this..
If you want to play DRM Amazon Music files on Raspberry Pi, then you can use this tool to help you. It is DRmare Amazon Music Downloader. It can convert Amazon Music to plain audios and you can save them to your device as local audio files. Then you can move the Amazon Music files to any device you like for playing.
DRM on Pi 4 with Ubuntu Mate 20.4:
(If you don't choose Mate, Raspian is the easy way)
The shown way with Docker-chromium-armhf from monkaBlyat works well.
Now I can play Music from Tidal to my headphones.
But - is there a way to direct the music-stream to an external DLNA-device,
which I connect via pulseaudio-dlna?
The DLNA-device appears in pavucontrol, but not the Container-Stream!!
