Is there any method to force caja desktop to not open? Caja is a great file manager, but the desktop is less stable than xfdesktop4.
remove the execute bit. you can find it in /usr/bin/caja
Hopefully the following link might be useful for the purpose
As i did niw also encounter several problems with xfdesktop i wrote my own desktop file manager using claude sonnet ai.
It does depend on -lm gio and gtk3. Also runs on icewm but nit on joewm
