How bout removing installed package?
I downloaded and installed a package with trial license and I want to remove it.
Thanks
Thanks
sudo apt-get remove --purge packagename
sudo updatedb
sudo locate packagename
sudo rm -rf (file/folder name)
For any beginners reading this, open Welcome > Software and find the package you want to remove and click on the remove icon (or install if you so desire!):
The package I installed was downloaded from the internet not on the software boutique and installed via terminal. I tried to find the uninstaller on package directory but there’s nothing.
And the name of the package is…?
Look here.
Code:
inxi -r
Should be a link to it. Use 'Software Sources' app to disable or remove it.
Edit: @wolfman
I was here first! How did you get ahead of me??
Learn to type quicker @anon42388993 ![]()
Ow…it’s edrawmax 30 days trial…just need substitute for visio.
I loaded up Edrawmax. The only directory created was in /opt. To remove in terminal,
sudo rm -r /opt/EdrawMax-8.2
Plus of course the original extracted folder and you should be done.
Thank s a lot…I will try this one …
I want to uninstall Google Earth, but can’t find the package name
I went through the source list and also did us inxi -r
Can’t find
It was originally installed from the web site. not from the Boutique
There seems to be a googleearth-package in the repos whose description says it will build a Debian package. So I assume it’s a script that downloads the binary and build a .deb.
It should work but it’s probably a better idea to go on the website and download the 64 bit deb (unless you’re on Ubuntu MATE 32 bit) then install it. I assume it’ll add a source list for its own repo to update it over time, it’s what Google usually does.
Understood. But on their site I see nothing that even refer to uninstall
So. If a .deb package I need to take another route to uninstall that what is referred to above in this thread.
Merci/Thanks
In my digging around I finally found this:
sudo apt remove google-earth-* && sudo apt autoremove
Your reply did help me give direction to my search. Thanks.
It works !
Oops, sorry, I misread your message, I thought you wanted to install it, not uninstall.
Anyway, a Debian/Ubuntu repository is just a server that hosts .deb packages. You can also install them manually. So, to uninstall a package, it doesn’t matter how it’s been installed, you can uninstall everything in the same way: you can use apt-get with the remove option as you did, you can also use Synaptic; it’s pretty useful to manage packages with a GUI. Even if it didn’t appear in the MATE Boutique, you would have found it in Synaptic.
