Hello everyone again here, this time I want to know how to completely eliminate evolution, not use that as Tunberbird is installed. The only thing I installed is mail-notification.
Thank you
Juanjo.
Thank you
Juanjo.
At a guess:
sudo apt-get remove evolution
?? wouldn’t sudo apt-get purge evolution
result in a more complete removal??
Yes, indeed, it would I suppose
Thank you for responding, I do not expressed well, it is as eliminating evolution, but it is safe to remove it, not because it is installed, from “boutique software” says that is not installed but is marked so, but from Synaptic is marked.
My question is whether to install mail-notification has been installed also eviolution.
Thank you.
Juanjo
I just solved from software boutique I have reinstalled and then deleted.
