Hi!
How can I REMOVE the edge [white-box] in Grub 2.02? (See picture)
I used "grub-customizer" for my Ubuntu-Mate 18.04-2 and the edge [white-box] shows special characters with $ when I use a background-picture.
Sorry, I have no picture for that.
Hi!
The short answer is you cannot remove it. IMHO the most probable reason is that grub now is using wrong character set. Some more information can be found here:
https://wiki.archlinux.org/index.php/GRUB/Tips_and_tricks
namely:
Oh, the following link might be of the interest too:
@mate2go
It appears this has nothing to do with fonts.
see terminal-box - console decoration link
http://wiki.rosalab.ru/en/index.php/Grub2_theme_tutorial
Coordinates of the console are constant and hard-coded. They can be changed using a patch
At first glance, to apply any patch woud mean downloading the source
patching the source
compiling the source
direct injection or creating a deb file
with the risk you break your boot loader and need a live cd/usb to
re-install grub 2 into the MBR
I assume you will not take that risk? ![]()
Thanks for the infos
That was my problem with the edge of Grub menu:
I've done it again with Grub Customizer and use another font from another theme and now the edge of the menu is linear.
Do not forget to mark your question as 'solved', please.
Thanks for the infos and help.
(SOLVED)
You can also change theme of grub easily. For example, check this one below. Instructions for terminal:
Thanks @ Philippe...
