How to run Viber.exe 32bit
I managed to install Viber 32bit through wine. (wine ViberSetup.exe). My question is how to run Viber after installation? There is no Viber when you browse wine. Thanks!
Interesting, Wine usually creates an entry in the menu when a Wine program creates start menu or a desktop shortcut.
You could manually navigate using Wine ("Windows") Explorer by pressing ALT+F2 and typing:
wine explorer
Then follow the directories like you would on Windows, something like:
C:\Program Files\Viber\Viber.exe
I have tried to browse also that directories but no Viber.exe found. I think, inorder to run Viber, I have to install 64bit. Hopeless.
