Hi!
Is it possible to slow down the gpu fan of my 2nd card from Radeon when it's driver blacklisted under
/etc/modprobe.d/...?
Because when the "amdgpu kernel module" is blacklisted, the gpu fan of the Radeon card is very loud.
I need blacklisted "amdgpu" for GPU passtrough with VFIO.
With enabled 'amdgpu' kernel module, the gpu fan of the Radeon card is quiet.
Is there a tool/workaround for slow down the gpu fan of the 2nd Radeon card without
enabled driver (amdgpu kernel module?
Card-name: ASRock Incorporation Vega 10 XL/XT [Radeon RX Vega 56/64]
Path:
/sys/class/drm/card1/device/
Files:
power_dpm_force_performance_level = Auto
power_dpm_state = Auto
pp_cur_state = 1
pp_force_state =
pp_mclk_od = 0
pp_num_states =
states: 2
0 boot
1 performance
pp_power_profile_mode =
NUM MODE_NAME BUSY_SET_POINT FPS USE_RLC_BUSY MIN_ACTIVE_LEVEL
0 BOOTUP_DEFAULT*: 70 60 0 0
1 3D_FULL_SCREEN : 70 60 1 3
2 POWER_SAVING : 90 60 0 0
3 VIDEO : 70 60 0 0
4 VR : 70 90 0 0
5 COMPUTE : 30 60 0 6
6 CUSTOM : 0 0 0 0
pp_sclk_od = 0
Path:
/sys/bus/pci/devices/0000:04:00.0/
Files:
pp_cur_state = 1
pp_force_state =
pp_mclk_od = 0
pp_num_states =
states: 2
0 boot
1 performance
3 VIDEO : 70 60 0 0
4 VR : 70 90 0 0
6 CUSTOM : 0 0 0 0
pp_sclk_od = 0
I want set "pp_power_profile_mode" to '5' - COMPUTE
How can I change the profile mode to COMPUTE?
Added to my rc.local in /etc/
#!/bin/sh
/bin/echo 1 > sys/class/drm/card0/device/driver/0000:04:00.0/hwmon/hwmon0/pwm1_enable
/bin/sleep 1
/bin/echo 45 > /sys/class/drm/card0/device/driver/0000:04:00.0/hwmon/hwmon0/pwm1
/bin/sleep 1
exit 0
"SOLVED"
