I have an ubuntu-Mate-based desktop, which I "upgraded" to kde neon and have been playing with for a couple of months.
I now wish to "upgrade" my installation to ubuntu-mate -- switching distribution from kde neon"
FYI
cat /etc/os-release
NAME="KDE neon"
VERSION="16.04 LTS"
ID=neon
ID_LIKE=ubuntu debian
PRETTY_NAME="KDE neon Developer Edition on 16.04 LTS"
VERSION_ID="16.04"
HOME_URL="http://neon.kde.org/"
SUPPORT_URL="http://neon.kde.org/"
BUG_REPORT_URL="http://bugs.kde.org/"
UBUNTU_CODENAME=xenial
I assume you had Ubuntu Mate installed before KDE Neon, can you just not simply remove the KDE Neon package(s) ?.
I personally would recommend a full install of UM 16.04 wiping both home and root and start afresh!.
thanks wolman.
Yes, i added neon repos to my apt sources.
i’m loathe to fully wipe because i’m running on zfs
so, I’ll try removing neon first
cheers
if you have Ubuntu Mate as your base system then remove the KDE Neon PPA as you already suggest and if it is a meta package, remove the offending package, that way you won’t have to do a fresh install!.
This is a ppa install?
What about using ppa-purge?
http://manpages.ubuntu.com/manpages/xenial/man1/ppa-purge.1.html
I prefer the terminal, but you can add a excellent GUI, “y-ppa-purge”.
