[Caja-Actions] (https://github.com/NiceandGently/caja-actions) will be fully integrated in Ubuntu MATE 15.04. Caja-Actions allows you to create custom extensions/actions for the Caja filemanager and has functionality very similar to Automator on Mac OS X.
To that end I have been working on packaging Caja-Actions and I’d like to get some testing feedback. I’ve back ported my changes to 14.04 and 14.10 and built everything you need into a PPA.
If you are feeling brave, let the destruction begin
sudo apt-add-repository ppa:ubuntu-mate-dev/crazy-mate
sudo apt-get update
sudo apt-get dist-upgrade
sudo apt-get install caja-actions
You’ll find Caja-Actions Configuration Tool under System -> Preferences.
debian
Package
You can find the source to my debian
package here:
Known issues
- None
