Is there a clear and simple way to permanently turn off the ESM "Pro" signup notice that appears after every software/system update?
Whether manually checking for updates or responding to an update prompt, all of them end with the requirement to click "Remind Me Later." There's no option to simply turn it off, so it's a recurrent nuisance.
I have a simple home single-user installation of 22.04.3 LTS 64-bit, and from what I've read it seems unlikely the ESM is needed. Having clicked on the other option, I bailed after encountering the privacy disclaimer. I'm quite reluctant to have any of my information collected, shared, or sold.
I'd like to turn off the nag notice, and would appreciate if someone could provide a clear and simple method that I can understand.
Thanks for considering this request.
