I’m running Ubuntu MATE 15.10 and FreeCAD (version .14) The latest stable version is .15. How do I update FreeCAD to the latest version?
take a look here:
http://www.freecadweb.org/wiki/index.php?title=Install_on_Unix
If you want the daily build which may break now and again!:
https://launchpad.net/~freecad-maintainers/+archive/ubuntu/freecad-daily
I added this repository: sudo add-apt-repository
ppa:freecad-maintainers/freecad-daily. When I try to update freecad
using Ubuntu’s Software Updater it fails with the following message:
W:Failed to fetch http://ppa.launchpad.net/freecad-mainta … 4/Packages 404 Not Found
, W:Failed to fetch http://ppa.launchpad.net/freecad-mainta … 6/Packages 404 Not Found
, E:Some index files failed to download. They have been ignored, or old ones used instead.
get it from here (not sure if its an “Alpha” or not?):
