I'm not able to connect the client to a x2go server. Please, how to use x2go to control desktop remotely?
On client side, X2Go client installed from the boutique : check
On server side, x2Go server installed from the boutique : check
Both have internet connected : check
Both, client and server, running Ubuntu Mate 20.04
Client is on a router different of the server.
On client, I set a new session with the IP public of the server, username, port SSH 22 and Mate in type of session.
Both have same username and password.
When I try to connect to server: error, time out.
Could you help me ?
Are you serious? With teamviewer, nomachine or anydesk no need to change settings of router or NAT. Machines are not on the same network. I want to use x2go by Internet.
With your comments, I can use X2Go on local network, but not over Internet. I discover that X2Go is not a desktop control remotely of a user but it open another session on the server, which is I don't want. Anyway, I give up with X2Go, because DWService is fixed:
DWservice is very simple in particular on server side, very efficient with very old person, as teamviewer.
