I’ve already visit the site http://www.hauppauge.fr/site/products/data_hvr5525.html and reserch for drivers and Linux, on support too, but there’s nothing with respect to this Europe’s PCIe card. They have solutions for old American cards on Linux 2!!! The TV system is not the same neither the hardware! What should i do?
Could i use Kobi to watch TV & listen to FM radio or there’s a better option?
I think that command should be like the following?:
sudo apt-get install kaffeine
Please bear in mind that the terminal installation commands are case sensitive, if you type any characters with the wrong name, it will throw out the command!.
Will do!
So saying, probably best to wait a while, Tvheadend 4.2 should be out soon, its web interface has changed quite a bit since the previous release (not to mention numerous fixes). Currently using nightly builds.
