Hallo
I have a problem. It’s strange, at least to me.
I have two machines running Ubuntu-Mate 16.04.3 attached to the same network-switch in my home office. One of them can scan from my network M377dw printer-scanner, the other can’t see the multifunction device’s scanner.
So I tried installing the “hp-plugin” on the machine with the problem.
Output of the command "sudo hp-plugin
name@name:~$ sudo hp-plugin [sudo] password for name: ERROR: ld.so: object 'libesets_pac.so' from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored.HP Linux Imaging and Printing System (ver. 3.17.10)
Plugin Download and Install Utility ver. 2.1
Copyright © 2001-15 HP Development Company, LP
This software comes with ABSOLUTELY NO WARRANTY.
This is free software, and you are welcome to distribute it
under certain conditions. See COPYING file for more details.
warning: It is not recommended to run ‘hp-plugin’ in a root mode.
(Note: Defaults for each question are maked with a ‘*’. Press to accept the default.)
| PLUG-IN INSTALLATION FOR HPLIP 3.17.10 |
Option Description
d Download plug-in from HP (recommended)
p Specify a path to the plug-in (advanced)
q Quit hp-plugin (skip installation)
Enter option (d=download*, p=specify path, q=quit) ? d
| DOWNLOAD PLUGIN |
Checking for network connection…
Downloading plug-in from:
Downloading plug-in: [\ ] 0% Receiving digital keys: /usr/bin/gpg --homedir /home/name/.hplip/.gnupg --no-permission-warning --keyserver pgp.mit.edu --recv-keys key
| INSTALLING PLUG-IN |
ERROR: ld.so: object ‘libesets_pac.so’ from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored.
Creating directory plugin_tmp
Verifying archive integrity…ERROR: ld.so: object ‘libesets_pac.so’ from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored.
ERROR: ld.so: object ‘ERROR: ld.so: object ‘libesets_pac.solibesets_pac.so’ from ’ from /etc/ld.so.preload/etc/ld.so.preload cannot be preloaded ( cannot be preloaded (cannot open shared object filecannot open shared object file): ignored.
): ignored.
All good.
ERROR: ld.so: object ‘libesets_pac.so’ from /etc/ld.so.preloadERROR: ld.so: object ’ cannot be preloaded (libesets_pac.socannot open shared object file’ from ): ignored.
Uncompressing HPLIP 3.17.10 Plugin Self Extracting ArchiveERROR: ld.so: object ‘libesets_pac.so’ from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored.
.ERROR: ld.so: object ‘libesets_pac.so’ from /etc/ld.so.preload cannot be preloaded (cannot open shared object file): ignored.
Traceback (most recent call last):
File “./plugin_install.py”, line 92, in
(UI_TOOLKIT_QT3, UI_TOOLKIT_QT4, UI_TOOLKIT_QT5), True)
NameError: name ‘UI_TOOLKIT_QT5’ is not defined
error: Python gobject/dbus may be not installed
Done.
name@name:~$
Can anyone help decipher what’s wrong and advise me on how to proceed?
PS hplip can’t install the device.
