Hi everybody,
I am experiencing some issues with my bluetooth headphones on Ubuntu Mate 18.04.
Whenever I turn on my headphones (by the way they are Mpow 059 in case it matters)
they connect to the bluetooth audio-sink and everything works fine.
The issue starts when I use them to listen audio in a browser and have to pause for some time
(for example, after watching a class in Coursera I might spend some time coding what I learnt in the lesson and so on). When I come back to the video the audio starts stuttering (like when you have very bad internet connection: it starts it stop, it starts it stop and so on).
To fix the issue I have to turn-off the headphones, turn them back on and re-connect manually to the bluetooth.
The same headphones work just fine on my Android mobile or tablet, even if I pause them for a while, when I get back to an app with audio, they work just fine.
I have no idea how to diagnose what the issue might be, could you give me some help to identify the problem and eventually fix the issue?
Thanks a lot!
Luca
