I would like to purchase an all in one printer for ubuntu. The Purchase price needs to be under $150.
The printer needs to work “out of the box” and perform as well in linux as windows without the need for any additional drivers. Turboprint would be one answer to my problem,but i do not want to buy it. Once i have a working printer in linux, balmer and gates can kiss my tail section!
I believe most HP printers work pretty well under linux. We have brother printers at my work that I use also with no problem.
I second the motion here. I have used HP printers for about 15 years and they have generally worked well with both WIN and Linux. They are probably the most compatible Linux printers around. I currently am using the HP ENVY 4500 All-in-One. You can order it here:
You might find this discussion in /r/ubuntu on Reddit useful. Someone asked a similar question there, about printer companies with good driver support for Ubuntu.
Thank you for the information and the link. I think i will give this one a try.
Thank you for your help.
Thank you for your help.Looks like hp is the way to go.
I have been using HP printers which work really well with Linux but I bought a new ink cartridge today and I am thinking about switching to Epson as the ink is waaaaaay cheaper than that of HP!.
Epson model XP-235 has Linux drivers which is what I would buy as I don’t need anything too fancy:
http://download.ebz.epson.net/dsc/search/01/search/searchModule
I’ve been using an HP Officejet 4620 for a year and a half as a wireless network printer with no issues, I configured the router to assign it a static IP so it’s always there, even after a power failure. I’ve never had any issue with HP printers on Linux though I’ve had to install the latest HPLIP a couple of times when the printers were too new for the standard Linux installed version
Oh, sorry I didn’t see the part about being under $150, I’ve never gotten a new all in one that was worth a damn that cheap. I don’t remember what my HP Officejet 4620 cost but it was over $200
I hope this never happens to any one else.
Epson printers used to enjoy a good reputation in my book - no longer.
The story begins around four and a half years ago…
MacBook Pro running OS X Snow Leopard (family member’s machine). Epson printer. Change print cartridges… actually it worked well enough for the first few replacements. After that it became a 30 minute battle to get the printer to recognise the fact that it’s belly was once agein full of Epson print cartridges. And the last time we had to change a cartridge it just stopped responding and stayed locked up in its loop-procedure, trying to detect the cartridges - and failing. I ran away… and bought an OKI C310dn.
I have had good luck with my Brother MFC-J480DW which is out of your pricing, but they have others.
$109.99 discounted to $89.99
I have found their support for Linux only second to HP which I agree has the best Linux support but Brother installation is a bit more complicated yet still relatively easy. I will say I had made a Mint USB drive for a friend an when I tested it Mint found the printer and put the drivers in on boot up.
I gave up on HP as every time I installed a new ink cartridge it told me it was not an original HP, which it was, then that it was a used cartridge which it wasn’t and finally I had to clean heads until all the ink was gone to get it to print. I agree there cartridges are very expensive. Next time I will look for a printer with an inkwell. The ink is cheap, the cartridges are expensive. This one might be worth the extra $9 bucks.
They are hard to find, but I will probably look for a black only printer. I almost never use the color ink, but to keep the heads from drying out a bit is used every time you print black. I am tired of buying color cartridge when I only print black.
Good luck, I hope you find what you want.
If you see a printer that you like, go check and see on their support page whether you can download the usual debian package to support it on Linux.
Well…I don’t want to be the disturber here…
But now in 2025, there is a professional printing store 2 streets from where I live…so print quality at its best. No bugs. No install. No on-going costs.
I gave my old (still working) Brother MFC to my sister.
When I travel, I always do find such shops quite near and handy.
Walking to them with a USB stick makes for a welcome walk… can send them electronically also, for pick-up later.
Just paying for the limited print job - which is not that often either.
So, my rational is: Why would someone need a printer these days ? Unless they are into some remote location. I am open to hear their own rational.
Cheers guys
W
"Scripta manent" is a Latin phrase meaning "written things remain".
I print my taxes every year
I print my monthly bank statement to reconcile my accounts
I print forms from American Airlines b/c they lost my wife’s suitcase recently
I print medications since each Doctor wants a copy
the list goes on ...
Being networked all the time helps but having paper receipts/forms/proof can get you out of a bind sometimes. Disclosure: I’m old, started with UNIX in 1975.
Yes I want hard copies of important documents. I even print out a grocery shopping list each week or in my old age I always forget something I needed.
