Hi again guys,
I was thinking if it is possible to change the size of the icons in caja, those that are in the left columns (places). I have been digging into defcon editor but I didn’t see anything.
Cheers.
Hi again guys,
Cheers.
Yeah I’m not seeing any matching config option.
Maybe you can submit a feature request up on github?
Well, I guess you can put bigger svg images in places inside the icon theme ??
Hi both,
Thanks for answering. I need to check the information available in Github although I can explore as well the second option if the icons are big enough to escalate them.
Many thanks although and malwaredpc.
Hi again guys,
I have been checking into the theme´s folder /usr/share/icons/ultraflat/places and there appear a couple of folders, one called “small” and a second one called “scalable”. Not sure which one is using… but should be a place where the size of the icons are defined.
