Hello,
I noticed in the boot process report that a swap file is used instead of the swap partition despite I created the swap partition when I installed Ubuntu MATE.
I have the following swap file:
$ ls -l /swapfile
-rw------- 1 root root 2147483648 Jan 31 15:34 /swapfile
And this is the output of swapon
$ swapon --show
NAME TYPE SIZE USED PRIO
/swapfile file 2G 0B -2
This is how I have partitioned my hard drives:
$ sudo fdisk -l
Disk /dev/sda: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 4096 bytes
I/O size (minimum/optimal): 4096 bytes / 4096 bytes
Disklabel type: dos
Disk identifier: 0x9f639bb5
Device Boot Start End Sectors Size Id Type
/dev/sda1 * 2048 206847 204800 100M 7 HPFS/NTFS/exFAT
/dev/sda2 206848 1953521663 1953314816 931.4G 7 HPFS/NTFS/exFAT
Disk /dev/sdb: 931.5 GiB, 1000204886016 bytes, 1953525168 sectors
Disklabel type: dos
Disk identifier: 0x2bb55f09
/dev/sdb1 2048 7929855 7927808 3.8G 82 Linux swap / Solaris
/dev/sdb2 7931902 1953523711 1945591810 927.7G 5 Extended
/dev/sdb5 7931904 1953523711 1945591808 927.7G 83 Linux
Partition 2 does not start on physical sector boundary.
As you can see, I have a swap partition. I created it in Ubiquity when I installed Ubuntu MATE. Why is it using a swap file and how can I use the partition instead?
Thanks in advance.
