The development team did a good job with this release. Only problem is i can't show battery percentage, but i guess that can be corrected later. This release is rock-solid and stable.
Try the Control Center -> Indicators -> Power -> Show percentage on the panel switch.
Yeah, tried your suggestion and it worked perfectly. Thank you!
