The below driver works on Ubuntu mate 18.04.1 only for printing.
The scanner application does not see the scanner.
On Ubuntu 14.04.5 (32 bit) the same driver worked just fine.
I tested the driver on Ubuntu mate 18.04.1 on 32 and 64 bit with firewall on AND off, but NO luck.
I installed the driver by unpaking it and right clicking on install.sh and run as administrator.
When the question about the firewall got printed in terminal, I tried with autoconfigure and with skip. I couldn't make the scanner work.
Thank you.
I was discouraged by the “trial” word as I already payd the workcentre that cammed with the drivers (only that the guis from XEROX had no clue how to install the linux driver and I had to dig online to find out.
Hello Marius, i would like your assistance in setting up my Xerox Workcenter 3025, I have the same issue, i can not install the driver package for the scanner (the printer is working just fine), could you explain to me in steps what should I do.
After you install the xerox driver by runing install.sh from the official driver archive,
Run in terminal: sudo ln -sfr /usr/lib/sane/* /usr/lib/x86_64-linux-gnu/sane
This will create a symlink for the folder /usr/lib/sane/ in the second location.
Then, I updated the file /etc/sane.d/xerox_mfp.conf using the command sudo pluma /etc/sane.d/xerox_mfp.conf
by adding the following two lines:
hello, I am new in Linux, i tried to run in terminal those lines but after reboot my operating system forced me to install a fresh copy of the Linux.
Could i get in touch with you on e-mail? could i call you on phone? I am from Romania.
Thanks!
