On a fresh install of Ubuntu MATE 16.04.2 Xenial on my Raspberry 2, and after running:
$ sudo apt-get update
$ sudo apt-get upgrade
$ sudo rpi-update
$ reboot
I wanted to install libgtk2.0-dev but I’ve got this error:
$ sudo apt-get install libgtk2.0-dev
Reading package lists... Done
Building dependency tree
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
libgtk2.0-dev : Depends: libglib2.0-dev (>= 2.27.3) but it is not going to be installed
Depends: libgdk-pixbuf2.0-dev (>= 2.21.0) but it is not going to be installed
Depends: libpango1.0-dev (>= 1.20) but it is not going to be installed
Depends: libatk1.0-dev (>= 1.29.2) but it is not going to be installed
Depends: libcairo2-dev (>= 1.6.4-6.1) but it is not going to be installed
As the distribution is up-to-date, ideally I don’t want to modify sources.list.
Does anyone have an idea of what could be done?
Thanks!
