mate beginner ,66 y old , no experience in installation
need help
installation PDF editor 4
version 5 has been installed without problems, but version 4 which is free makes me problems
will be very happy to find help
ahab66
dear sir
i am on the begining of as i see a long way
instalation of main programs is finished
i installed panda go, kgs go
but with PDF editor has a lot of problems
have not yet installed voice communication and will be happy to tipe to me
Is this Master PDF Editor by Code Industry?
Which package did you download: .tar.gz? .deb? .rpm?
How are you trying to install?
What errors are you having?
I don't use that software, but usually the easiest path to install a non-ubuntu-repository package is to download a .deb, and install with gdebi. IT SHOULD BE INSTALLED IN THE /usr/local TREE, NOT THE DEFAULT LOCATION. This will help prevent conflicts with ubuntu-repository packages.
Also, you probably know this, but the PDF format is not really designed for editing. YMMV.
thx charles
it is code ind
tar
i wil tray
tjy
i am interested in archeology and on windows were working 20 y with acrobat profesional
to make annotations
links etc
I'm 60 years old but always follow tech .
Now i use manjaro-mate and i think libre office will cover you in any way just learn it!
thx joe
very helpfull
t
