Stupid question (as ever).
I have a working flash based installation of 20.10 on a Pi4 which I boot from in a USB adaptor - all good. However I was getting tight on space so thought I'd do it "properly" and install to a real usb drive. So I did:
- Write the downloaded 20.10 mate installer (originally used) to a new SD card
- Also plug in an external USB drive on a sata to usb adapter which works fine on the current working SD card based instance
- power on and start going through the install
Thing is - I'm never asked what type of installation I want (basic/download updates/no free s/w) and it never asks where. I go through keyboard, wifi and location then it skips to user/machine/pwd and then begins installing....
Am I mad in thinking it should ask where to install?
Thanks
