Installed a bunch of updates and now LibreOffice won't stay open
I'm not even sure that this is where I should be bringing this issue. I'm bringing t here mostly because I'm not sure if the issue is with LibreOffice itself or with some other update that's interfering with it. I tried doing a rollback using this command:
sudo apt-get install ppa-purge && sudo ppa-purge ppa:libreoffice/ppa
That didn't seem to do anything other than tell me that it couldn't find the package. It is installed though. I went to the software boutique to try to uninstall and reinstall it, but the option to uninstall it wasn't even available. So, I did an install from App Grid as it seemed to think that it wasn't installed. Still no joy. I open up a document, and it closes immediately. Does anyone have any idea about what the problem could be and how to fix it?
So, I tried opening up LibreOffice in a terminal to see what kind of error messages I might get, and this is what popped up:
(soffice:12252): Gdk-WARNING **: gdk_window_set_icon_list: icons too large
The last time LibreOffice updated the icons were visibly too small. I hadn't used a terminal to open it, and it was able to stay open without crashing, but the icons were too small. Now I'm getting a message that they're too large. I'm just wondering if this is just LibreOffice or if there is something about 16.04 that doesn't mesh well with this software. I've read a few comments (not here) that others have had problems with it on 16.04 as well.
I saw this as a potential solution on the askubuntu forum:
I was able to solve the problem by installing the xserver-xorg-video-intel package. Seems to be a problem with the generic modesetting xorg driver in my case.
The thing is that I already have the xserver-xorg-video-intel package installed. There's another package that can be installed instead: xserver-xorg-video-intel-hwe-16.04. I'm just not sure what swapping those out will do to my system. Is anyone familiar with the difference between these two packages?
Hi @Van_Burgett, I’m guessing something in your configuration settings may be corrupt or incompatible. It’s in your home directory at:
~/.config/libreoffice/.
If you delete or rename it, it will be created again when you run something. Here is a terminal command to rename it:
mv ~/.config/libreoffice/ ~/.config/libreoffice.old/
Sorry, I’m not familiar with the Intel xorg packages. I’d try the config first.
Wow! Thanks so much. That seems to have done the trick.
Great! You can delete that old directory since it has no use, now.
