Installed initramfs-tools package post-installation script subprocess returned error exit status 1
Starting last week, one of my system running 25.10 started giving me the following error:
update-initramfs: Generating /boot/initrd.img-6.17.0-14-generic
cp: cannot stat '/etc/fonts/fonts.conf': No such file or directory
E: /usr/share/initramfs-tools/hooks/plymouth failed with return 1.
update-initramfs: failed for /boot/initrd.img-6.17.0-14-generic with 1.
dpkg: error processing package initramfs-tools (--configure):
installed initramfs-tools package post-installation script subprocess returned error exit status 1
Errors were encountered while processing:
initramfs-tools
I’ve checked a couple of references, such as https://askubuntu.com/questions/1136480/initramfs-error-when-installing-updating, yet none of them managed to provide me with a solution.
The most exhaustive answer I found was to run the following:
sudo apt remove initramfs-tools
sudo apt clean
sudo apt install initramfs-tools
sudo apt-get autoremove
sudo apt-get autoclean
sudo apt-get clean
sudo apt-get update
sudo apt-get upgrade
sudo apt-get dist-upgrade
sudo apt-get -f install
sudo dpkg --configure -a
Sadly after doing so, it did not fixed my problem:
$ sudo apt remove initramfs-tools
sudo apt clean
sudo apt-get clean
sudo apt-get update
The following packages were automatically installed and are no longer required:
  3cpio  busybox-initramfs  dracut-install  initramfs-tools-bin  initramfs-tools-core  klibc-utils  libklibc
Use 'sudo apt autoremove' to remove them.
REMOVING:
  initramfs-tools
Summary:
  Upgrading: 0, Installing: 0, Removing: 1, Not Upgrading: 2
  1 not fully installed or removed.
  Freed space: 66.6 kB
Continue? [Y/n]
(Reading database ... 381788 files and directories currently installed.)
Removing initramfs-tools (0.150ubuntu3.1) ...
Processing triggers for man-db (2.13.1-1) ...
Installing:
  initramfs-tools
Summary:
  Upgrading: 0, Installing: 1, Removing: 0, Not Upgrading: 2
  Download size: 8,440 B
  Space needed: 66.6 kB / 26.5 GB available
Get:1 http://ca.archive.ubuntu.com/ubuntu questing-updates/main amd64 initramfs-tools all 0.150ubuntu3.1 [8,440 B]
Fetched 8,440 B in 0s (109 kB/s)
Selecting previously unselected package initramfs-tools.
(Reading database ... 381778 files and directories currently installed.)
Preparing to unpack .../initramfs-tools_0.150ubuntu3.1_all.deb ...
Unpacking initramfs-tools (0.150ubuntu3.1) ...
Setting up initramfs-tools (0.150ubuntu3.1) ...
update-initramfs: deferring update (trigger activated)
Processing triggers for initramfs-tools (0.150ubuntu3.1) ...
 initramfs-tools
Error: Sub-process /usr/bin/dpkg returned an error code (1)
Reading package lists... Done
Building dependency tree... Done
Solving dependencies... Done
0 upgraded, 0 newly installed, 0 to remove and 2 not upgraded.
After this operation, 0 B of additional disk space will be used.
 initramfs-tools
E: Sub-process /usr/bin/dpkg returned an error code (1)
Hit:1 https://linux.teamviewer.com/deb stable InRelease
Hit:2 http://ca.archive.ubuntu.com/ubuntu questing InRelease
Hit:3 http://security.ubuntu.com/ubuntu questing-security InRelease
Hit:4 http://ca.archive.ubuntu.com/ubuntu questing-updates InRelease
Hit:5 http://ca.archive.ubuntu.com/ubuntu questing-backports InRelease
Hit:6 https://download.sublimetext.com apt/stable/ InRelease
Hit:7 https://repo.librewolf.net librewolf InRelease
Hit:8 https://ppa.launchpadcontent.net/mozillateam/ppa/ubuntu questing InRelease
N: Missing Signed-By in the sources.list(5) entry for 'https://download.sublimetext.com'
Calculating upgrade... Done
The following upgrades have been deferred due to phasing:
  cloud-init cloud-init-base
Do you want to continue? [Y/n]
 initramfs-tools
 initramfs-tools
 initramfs-tools
 initramfs-tools
I am running 25.10 on 2 similar systems and am only having this problem with one.
Try this command: file /etc/fonts/fonts.conf
it should return:
/etc/fonts/fonts.conf: XML 1.0 document, ASCII text
If it returns
/etc/fonts/fonts.conf: cannot open /etc/fonts/fonts.conf (No such file or directory)
you might want to copy this file from your good system to your bad system and see if that works.
Fixing this font.conf error did indeed fix my initramfs issue, thank you <3
