Hello! I tried to install amule the quick way, namely
sudo apt-get install amule
but I got an old version full of bugs.
Anybody knows if there is a step-by-step guide to install the latest version from amule.org?
They provide an installation guide here, but it is outdated and has problems.
Thank you!
Hi @Mario.R,
ver: 2.4 is showing in Synaptic which is actually later than the version shown on their own website?, have you done any reloads to your sources lists lately?:
See the update guide for more info about your sources lists if you don't know anything about it:
Then try running your terminal (Ctrl + Alt + t) install command again:
Wow, now downloads are ~100 times faster
Thank you!
Hi @Mario.R,
did it fix your problem and can we mark this as solved?.
