Hello all. I'm a newbie so take it easy on me and thanks in advance for as much detail as your patience will allow!
I've downloaded a couple of cursor packs that I'd like to try out. Could someone walk me through how to do that with 20.04? I've looked up the process on a couple of other sites and the "gnome-tweak" tool comes up a lot. I installed that and it did not include the tools to "add cursors" or adjust size or color or anything of that nature. Being that Cursors and their icons are likely sort of "all over the place" depending on the processes they're supporting I figured it might be wise to check with someone way more advanced than I am! One of the packages has numerous size options, 24/36, etc and I really like the look of them. I run a dark theme and thought this would be sharp and stand out a bit. Check 'em out: https://www.gnome-look.org/p/999804/
Anyway, thanks again for your time and help & please remember, I could really use the help to be by the numbers until I get my command line chops back and familiarize myself with this distro. Thanks!
