If so, what is it formatted as currently? If it is ext4 or some other Linux type of file system, MS Windows might not be seeing because of that. It that is the case, you can format the USB stick in Linux as fat 32, then fire up your VM again and connect the USB and see if MS windows can then see it.
If not, not a problem as I can show you another way to share files that does not require an external USB stick. You can directly share a host folder. But I will have to do that tomorrow cos I got to go to bed,
Yes, a USB stick. It is formatted and running under Windows.
UM can see it and shows all the files. In fact when VB starts up and I select it, it disappears from the UM desktop.
I am using PRO, you are using Home or something else. Could that be the difference?
See you tomorrow. I will get up early and let you know I am here.
You sure are going the extra mile helping me at 1am your time.
I really appreciate this.
************ Ignore all this I found the problem in message 64 ***************
Food for thought.
Below are two screen shots that show VB is aware of the USB stick, but it is not passing the information to W7, which I showed you in message 60 using the disk management screen.
Could this be the problem? It is not using USB 2 and the stick is. And that turned out to be the problem, you have to select which USB 1,2 or 3 FIRST and then it finds it.
Meanwhile I have installed one of my wireless printers in W7
Just need to get the installation file for the other.
First I need to make sure there isn't a Linux one.
Life is getting better.
Thanks for another great video, just did it and everything worked as promised.
Off to Southern California to visit our son for 10 days.
Catch up with you when I get back.
Something that i came across recently to watch out for - my BIOS had virtualization disabled. That screwed some things up until someone here helped me diagnose that the problem was in my BIOS virtualization setting.
