Intel 7260 wi-fi issues (bluetooth works fine)
I am having some strange issues. I’ve spent a few days, but so far I haven’t been able to find a solution to my problem.
I’m running Ubuntu Mate on a Raspberry Pi 2. Bluetooth seems to be working (I can see the Pi on my phone under bluetooth devices). However, the wi-fi doesn’t work.
The output of running
ls /lib/firmware | grep 7260
is
iwlwifi-7260-10.ucode iwlwifi-7260-12.ucode iwlwifi-7260-13.ucode iwlwifi-7260-7.ucode iwlwifi-7260-8.ucode iwlwifi-7260-9.ucode
So I am assuming that I have the firmware that I need.
I would be really grateful for any suggestions.
with a network cable connection, run the following commands and restart if anything updates:
wolfman, thanks for your reply. Unfortunately nothing was missing or broken. Can the wi-fi part of the driver be disabled somehow?
It’s a BT/wi-fi card that I’m using, it’s connected using a USB-adapter (without external power).
Hi Martin,
what model number is it, it should be written on the stick somewhere and tell what chipset it uses!. :smiley:
Sorry, what do you mean by “it”? The BT/wi-fi card, the USB adapter, or the Pi?
The USB adapter is similar to this: http://www.amazon.com/Mini-PCI-E-Wireless-Adapter-Module/dp/B00RZ5JKMC
Hi Martin,
sorry yes!; I did mean the BT wireless!. :smiley:
Open a terminal and type the following command:
lsusb
and report back with the contents, you will get something like the info below:
wolfman@fred55:~$ lsusb
Bus 001 Device 006: ID 058f:6366 Alcor Micro Corp. Multi Flash Reader
Bus 001 Device 005: ID 03f0:8c11 Hewlett-Packard Deskjet F4500 series
Bus 001 Device 002: ID 046d:0807 Logitech, Inc. Webcam B500
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 003: ID 046d:c018 Logitech, Inc. Optical Wheel Mouse
Bus 002 Device 002: ID 04f3:0103 Elan Microelectronics Corp. ActiveJet K-2024 Multimedia Keyboard
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
wolfman@fred55:~$
The device you show from Amazon; states it is ONLY FOR TESTING!.
This is the output:
Bus 001 Device 007: ID 046d:c01b Logitech, Inc. MX310 Optical Mouse Bus 001 Device 005: ID 8087:07dc Intel Corp. Bus 001 Device 006: ID 05ac:0205 Apple, Inc. Extended Keyboard [Mitsumi] Bus 001 Device 004: ID 05ac:1002 Apple, Inc. Extended Keyboard Hub [Mitsumi] Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter Bus 001 Device 002: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I realize the text said “only for testing”. However, the bluetooth works fine, so I’m just curious why wi-fi doesn’t seem to work.
According to your feedback, you have no connected USB WIFi device, at least none I can see?.
Open Control Center > System > Software & Updates > Additional Drivers and let the tool run and see if anything shows up driver wise!.
Another option is to install the following package via a terminal (Ctrl + Alt + t):
sudo apt-get install linux-firmware-nonfree
and restart with the dongle attached to the PC!.
Please try and find out the model number/name of the BT dongle!. :smiley:
Try what @wolfman said, some Intel Wifi chips require additional firmware.
As an example, the BT dongle below doesn’t have Linux support!:
https://wikidevi.com/wiki/BT_Wi-Fi_Dongle_300_(075714)
(It is stated on the right hand side of the page: “Probable Linux driver = none”).
That said, it is possible to use the Windows drivers to get it to work using “ndiswrapper” if you get the correct Windows driver package for your model!:
See also (reference Bluetooth v WiFi):
Hi again. Thanks for your replies. I’m sorry I didn’t reply before now - I have been without internet at home (except 4G via my phone) since January. Finally with 50/50 mbit.
Anyway, I tried what you suggested. Nothing shows up under Additional Drivers, and when I run the command in the terminal, I get “linux-firmware-nonfree is already the newest version”.
So I’m probably going to give up on this adapter and get a Raspberry Pi 3 at some point instead. I could then use this device for something more permanent.
I will spend a bit more time investigating.
