Internal battery not identified
I have an HP Envy. UM 23.10
The system doesn't identify the internal battery (see image). It's been the same with previous UM versions.à
One of you know how to correct this situation ?
Thanks
W
I know nothing about your system, but your post got me curious because the line you highlight does have identification: elan2514. So, I did a quick search on that, and found that device is apparently the touchscreen on the HP Envy, not a battery:
Touchscreen ELAN2514 not properly detected in HP envy x360
Don't know what command you are using to get the screenshots but on my Dell using the commands below it shows my battery (UM 22.04.3).
mendy@mendy:~$ upower -e
/org/freedesktop/UPower/devices/line_power_AC
/org/freedesktop/UPower/devices/battery_BAT0
/org/freedesktop/UPower/devices/mouse_hidpp_battery_0
/org/freedesktop/UPower/devices/DisplayDevice
mendy@mendy:~$
mendy@mendy:~$
mendy@mendy:~$
mendy@mendy:~$ upower -i `upower -e | grep 'BAT'`
  native-path:          BAT0
  vendor:               Samsung SDI
  model:                DELL TWCPG66
  serial:               39759
  power supply:         yes
  updated:              Tue 26 Dec 2023 10:13:32 AM EST (15 seconds ago)
  has history:          yes
  has statistics:       yes
  battery
    present:             yes
    rechargeable:        yes
    state:               fully-charged
    warning-level:       none
    energy:              70.7142 Wh
    energy-empty:        0 Wh
    energy-full:         70.7142 Wh
    energy-full-design:  90.9948 Wh
    energy-rate:         0.0114 W
    voltage:             12.051 V
    charge-cycles:       N/A
    percentage:          100%
    capacity:            77.7124%
    technology:          lithium-polymer
    icon-name:          'battery-full-charged-symbolic'
mendy@mendy:~$
Rereading your post above is for laptop battery, if talking about the CMOS battery maybe some information here:
https://www.linuxtoday.com/high-performance/how-to-check-cmos-battery-status-in-ubuntu-18-04-lts-19-10/
