I have been searching and doing everything I can for the last three days but for some reason I cannot use either the internal microphone on my laptop or if i connect earphones with a mic.
I recently installed the Ubuntu Mate 16.04.1 and I am in love with it.. I have an ASUS X540S when i go to sound preferences all I see in input devices is "Monitor of Built-in Audio Analog Stereo" as an option and that is it!
Please help me out fix this as i don't want to move away from ubuntu mate.. its the best OS ever..
Tried it still not working⦠Guys can someone help out? Where can i get Ubunte mate help from? I came here because this is the official community⦠please help out if someone can
Didnāt sound work in another distro? Then chances are your hardware is not compatible with Linux. Maybe a more technical user like @ouroumov , @anon42388993 or @lah7 can help you out and see if your hardware is recognized by the Linux kernel.
Donāt give up. Ask for help in other places too, like askubuntu.com
The good thing about using an Ubuntu-based distribution is that you can search for help in a lot of different places and forums. Also google your hardware+Linux which might give you quick info about compatibility.
Go with your arrow key -> to Mic, if this is a empty bar...then type m , if you do that you will see under the bar it will change from MM to OO.
It has to be OO. than go with your arrow key ^ all the the way up in the red zone.
It looks something like this,
Hey! Thanks for the reply.. well the thing is i already tried this as well before i posted this thread.. but in my alsa mixer i do not see any mic/microphone anything :S.. although weirdly in the start even pulsemixer was not recognizing any microphone.. after a few days pulsemixer started showing microphone as an input but it still does not work.. i tried unlocking and bringing left and right volumes to 0 as well.. still to no avail..
Hi @Mazin_Asif. The mic may show only when you press F4 to see the āCaptureā controls. Note how the upper left has help and also displays the selected control in detail.
Hello again @Mazin_Asif, It“s like Bill_MI mentioned, there are more options to extend the settings.
So...can you go back to the alsamixer and press F5 for the full display of settings.
