I use Openbox as my window manager along with Mate. I like to use the keyboard as much as possible and I know I’ve seen the command I need, somewhere…someplace before, I just can’t find it.
Ideally, I’d like to bind a key-binding with the pop up of the menu.
I’ve looked at all the options under mate-menu mate-panel (on the command line).
In gnome2 it used to be gnome-panel-control --main-menu, I belive.
I know it’s there, just doing my head in that I can’t remember.
